So I have to say that I really hate the ARB in our Dynatrac PR80. Very early on, it started leaking air from inside the differential. I tried to make sure to always run dino fluid as is recommended and have had the o-rings replaced more than once and the leak just kept coming back. But, as annoying as hell as it was to have the compressor run on and off and on again, at least the locker would work when it did. Just recently, that on and off and on again turned into a solid ON and after giving things a closer look, I found that the locker will NOT engage when this happens. It'll try to engage but then it'll let go. And, while the simple answer is to just replace the friken o-rings again, and I say friken because it's a major PITA, I've found that it's either been discontinued or just really really hard to come by these days. Just about every vendor out there says they'll "drop ship" from ARB once they become available but that might be as much as 2 months out. While I'm sure I'll find or figure something out but this whole thing has been such a pain in the ass, I'd have to say to SKIP THE ARB if you're thinking about getting a PR80! And, I should note, I have run ARB's for years and have always loved them but this one or at least, on this particular axle is a total dud.
Anyway, just thought I'd share some real world experience with the hopes of helping others out.
EDIT : I've looked and don't think the PR80 is available with anything other than an ARB
