I can barely get the tailgate CB mount to work with the AEV carrier (don't remember which model, likely not EVO), but I had to grind down the knurled connector to clear. I might pick up a high-lift mount and try to put it there.
Thanks again, will probably PM you with questions today. How did you measure how to cut the fascia minimally? Did you mount it first, then put the AEV bracket over it to mark it?
I usually mount a flag where you have the antenna. If I picked up a really short antenna, it might work there as long as it clears the garage shop door.
My biggest issue is going to be getting the bracket off of the AEV bumper. Every single knurled stud in the water tank is spinning!
Thanks again for the post Coloradan. A lot of grinding, grunting, groaning, bitching and moaning on my part, but I'm happy with the result.
I need to get the hi-lift mount eventually and polishing compound out the marks where the old license plate mount was, but otherwise complete.
Oh, and the stock muffler NEEDS TO GO! Dynomax Quiet Crawler just made the list for next purchase I think.
Looks good Buster!Thanks again for the post Coloradan. A lot of grinding, grunting, groaning, bitching and moaning on my part, but I'm happy with the result.
License plate moved. Will paint the lower body black once I get time
AllAmericanInfidel;Nice looking rig! And side shots?[/QUOTE said:
