bkac
I would like to warn you and yolo that anything that is touching WILL eventually cause wear and line damage. All it takes is persistent vibration over the span of a year or so to cut through those soft lines.
This is the whole reason for the recalls on the '13 wrangler where the tranny line and power steering rub causing damage and a hole. I wouldnt Zip tie, I wouldnt let anything even slightly touch. Either bend it out of the way GENTLY, use a spacer on the sway bar to lower it slightly, or rotate it the oposite direction. :twocents:
I totally agree, i think that's why i was asking what to do. I flipped it forward but it put it really (1/16) front the ac condenser. I just installed the front coilovers and indeed if i turn the motor downwards my drag link does hit the motor. So i found my answer out. It won't work for the set up i have. I'm going to order the evo front drag link. It's all good, just sucks because the synergy is only 1000 miles old. I just didn't want to have issues later like your talking about with rubbing down the road. I have a solution to my problem now. Thanks for the input.
