EVO rear corner skins install
bkac
How did you install the reverse lights? Getting ready to install these and like the clean look of the lights?
On the drivers side I used the two license plate holes and drilled a third, then I matched the passenger side to the drivers side. I then just wired them straight up and into the reverse wire of the factory harness. It's really simple. Good luck!
hbkid22
I am not the greatest with electrical....did you get any extra relay's or fuses or just splice the wires directly into the factory wires? And what is the max watts you can run directly into the factory lines?
