That’s about the most accurate equation I’ve ever seen
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Learned it from my buddy Albert E.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Should I be able to see the tube like this? This is the bottom side of the passenger tube into the front pumpkin. View attachment 340781 View attachment 340782
Sent from my SM-G975U using WAYALIFE mobile app
Jeep = = :broke: Yet still =
Hell if I'm going to put money into the front axle I might as well just buy once cry once and step up. I just called Dynatrac and he said I potentially could have bent the front axel thus causing the leak.
I guess it could be possible because out last week coming down one of the open dirt roads about 45 miles an hour hit a gnarly hole on that side of the Jeep and now its leaking. Heading back home to see if it's visually bent.
I know it sounds a little ridiculous to go from a inner seal leak to buying a front PR44 but I'm also the type of person that says why throw money at something when it's going to give me a potential issue down the road.
I still need to put C's on it, now i need to replace a seal, and if it is more than a seal it just more to spend.
I've been holding off gearing my Jeep because I didn't want to throw money into the stock axle well now hear is my opportunity.
New inner seal come in a PR44 so that should fix that problem.
I was looking at pulling the trigger on the Evo coilover kit in the upcoming months but looks like the axle is going to take place first.
Wow that escalated quickly.
Best quote today!
Get the PR44, get it with 5.13 gears, and regear the rear also. It will feel like a new Jeep.
Then I would tell your wife yours is bent too.
What the hell why not, seems like everybody else to getting new axles.
Are you feeling left out??
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Gonna give Bubba a call tomorrow after talking to my Warden tonight.
Can i still take the jeep out wheeling and just keep an eye on the oil level?
Thanks!If it’s dripping it has fluid. Do whatever.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I like the logic . Mine rear end is sagging and it’s leaning . Probably need to trade out the springs for some coil overs . But then could be the axle so should swap in some 60s to be safe ... [emoji848]
