^^^ this. i got quoted from dynatrac last year sometime on a PR44. it had 5.13 gears, oem ball joints, arb locker, unlimited housing, custom length 30 spline chromoly shafts with full circle clips, and 1310 u joint. all for just under 4k. here is the invoice
JK44-1X3010-B
| 1
| Custom Dynatrac Pro Rock 44 Partial Front Axle Assembly w/ARB Air Locker - '07-12 Jeep JK
| 3,837.00
| 3,837.00
General Dynatrac Axle
| 1
| Dynatrac Pro Rock 44 High Pinion, High Ground Clearance Heavy Duty Nodular Iron Housing
| 0.00
| 0.00
| 1
| Heavy Duty 3.0" Diameter, 5/16" Wall DOM Housing Tube Assemblies, Installed
| 0.00
| 0.00
| 1
| Dynatrac Unlimited Pro Rock 44 Housing Upgrade, Provides Extra Caster & Shock Mount Relocation for 3+" Suspension Lifts - UPGRADE
| 89.00
| 89.00
| 1
| Stock JK Axle Width - 65.5"
| 0.00
| 0.00
| 1
| Dynatrac Heavy Duty 3/16" JK Coil Spring Suspension Brackets, Installed
| 0.00
| 0.00
| 1
| Dynatrac Raised Track Bar Bracket Modification for High Steer/Flipped Drag Link Applications - Optional Upgrade = add $79.00
| 0.00
| 0.00
DA44-1X4033-F
| 1
| Dynatrac Heavy Duty Pro Rock 44 Nodular Iron Powder Coated Differential Cover, Installed
| 0.00
| 0.00
| 1
| Dynatrac Heavy Duty Pro Series 44 JK End Forgings, Installed
| 0.00
| 0.00
| 1
| Heavy Duty Open Differential, D44, 30 Spline, Installed
- (Upgrade to ARB Air Locker Differential, Installed = add $439.00)
| 0.00
| 0.00
| 1
| D44 JK New Generation 5.13 Reverse-Cut Ring and Pinion, Installed
| 0.00
| 0.00
JP44-4851-C
| 1
| 1310 U-bolt Style Pinion Yoke, Installed, w/Yoke Kit
- (Upgrade to 1350 Yoke, Installed = add $29.00)
| 0.00
| 0.00
| 1
| Custom Length 30 Spline USA-Grade 4340 Chromoly Inner Axle Shafts, Fit Stock JK 1310 U-Joint
- (Upgrade to Heavy Duty RCV Performance USA Grade 4340 Chromoly Inner and Outer Ultimate CV Axle Shaft Assemblies w/RCV's Lifetime Warranty = add $796.00)
| 0.00
| 0.00
| 1
| OEM JK Ball Joints, Installed
- (Upgrade to Dynatrac ProSteer Heavy Duty Ball Joints, Installed = add $499.00)
| 0.00
| 0.00
| 1
| Customer to Reuse Stock Wheel End Components (Knuckles, Hub Bearings, Disc Brakes, Outer Axle Shafts, and U-joints)
| 0.00
| 0.00
Subtotal
| 3,926.00
