Hawaii 5-0
Does a vented hood increase your chances of sucking water into your air intake and hydro locking?
I
On another note: I keep reading 10A hood considerations, All three of the 10As I have seen only had foe louvers or vents. (It's just for looks) Is there a conversion or other option out there where they are functional?
Ok, for ANYONE wondering if these actually work, here is some proof. These pictures (taken from another forum and used by me solely for the purpose of providing information on this subject) were taken with an infrared thermal imager before and after psc louver installation. Read the comment in the picture for an explanation of what you are seeing.
View attachment 51336 View attachment 51337
So if you need proof, aside from the many people providing us with their positive experiences with hood louvers, there ya go Hopefully someone can find this useful.
I'm looking at this from my phone so it's hard to be sure but it looks like about four degrees. Is that right? Was kind of hoping for a larger difference if that's the case. Thanks for posting this up.
ttfhell, negative. I'll explain. The first pic shows the temp of the metal top and center of the hood. You will notice the operating temp there shows us 60 something degrees. The second pic explains why it is that cool in that portion of the hood. The second pic shows us that heat (90*F) is being expelled out the side and bottom of the hood. This is not good because heat naturally rises; thus, heat is not able to escape your hood efficiently or fast enough. It's being kept inside. The third or last picture shows us that with the louver installed the heat is allowed to follow its natural tendency and escapes the hood upwards as it's supposed to; thus, speeding up the cooling of the engine bay. It goes from 60 degrees in the first pic to 90 degrees in the third pic, meaning there's 30 extra degrees of hot air escaping through the top. That's impressive.
Got it. Thanks!!! Trying to read from my phone and my lack of intelligence confused me.
My plan is to pull the mat before I add louvers. In summer run with it off and then in the winter put the mat back in (essentially plugging the louvers).
i would be very careful doing this, since the mat would probably soak up extra moisture that comes in throgh the vent and turn into a nasty spong quick. I am probably wrong but I feel it would be likely to happen.
