No your wrong and a troll. Crown is $100 for a set if four and synergy is $200 for a set of four. Myself and other good friends just went through this. They bought the crown and I got the dynatrac which is better then both.
I came across the Dynatrac they seem to be the way to go just by looking at them, I can't remember price difference but you usually get what you pay for.
I got a stupid question though, if my stock ones are damaged by welding on the gussets what will be the symptoms if any?
If they are damaged I want to replace them sooner than later and would like to know what to look for.
It looks to me like there are normal Crown ball joints and heavy duty Crown joints. The normal Crown are about 1/2 the price of the heavy duty Crown joints. I assume I would want the heavy duty ball joints?
I had read about this method somewhere, thank you.
I would think there would be some other effect when driving it since it seems to be so common, maybe I'll just replace the damn things and get it over with.
It is possible to get death wobble from bad ball joints. Also your ball joints don't have to have that much movement for them to be bad. It may not even be noticeable.
Trust me I have the crown HD ball joints, $100 for both sides compared to $200 or so for both sides. My crowns are greaseable
Quick question considering im looking into ball joints, whats the wear been like with the crowns? Do they have similar lifespans as synergy and the other more expensive ones? Ive researched a little bit so if theres already a thread on this my bad. Id like some better quality Ball joints than stock but not as expensive as something like the dynatracs.
I didn't want to start a whole new thread since this is kind of on topic of what I'm asking anyway.
Is there risk of bending stuff having just inner c gussets installed? I only have 285/75 17's but still think I should put em' on just in case so I ordered them - using a reputable welding/fabrication company for install.
Thanks
Now this is the kind of thread I like on this forum. Lots of good info supporting a reasonable question. I read every reply and took notes. As someone who is slightly cash strapped, I try to improve on stock and hope for the best. Good stuff!:thumb:
Go back home to the island.
well, aren't you special! dynatrac wow I'm so impressed... since when does stating a fact make me a troll? pricing is direct from Quadratec for the Crown HD, not the cheaper normal ones which can be had for $100.
but if it has to be, I'd guess I'd choose to be a troll with valid information than an asshole like you who spews nothing but shit the majority of the time along with what ever you can regurgitate because you think you're so special...which you are but not in the way you think.
Why not try doing a bit more research before you spew what you think you know. Just because you have dynatrac does not make you as special as you think.
If you happened to find the HD's full set for $100 that's great! but you don't have to be an asshole all the time....
Sorry me math no so good. You splain to me how 2 x 44.99 = $180 using your boolean algebra for us.
