I quickly added in the synergy misalignment spacers after seeing a lot of rub marks from a bolt on my tie rod flopping. For how cheap they are, its worth it right away. I also run a cooler, but I am running the larger upgraded PSC hoses for the 12+ system. For how low the cooler mounts, I dont see it blocking any airflow and why not just add one in for added peace of mind? Also running the tie rod clamp for the ram, felt it made more sense than welding tabs since I already swapped tie rods once so far and have to fine tune the location.
Correct me if I'm wrong because I'm not a welder, but a lot of the aftermarket tie rods are chrome moly and I was told that welding to it weakens it, hence why everyone uses the clamps.
Good to know - I'll grab the spacers. How are they for actually holding in grease?
I might grab a cooler down the road, but I think I'll be fine for a bit. Low miles so the pumps still pretty strong.
That's what I thought as well - I heard that the clamps have a tendency to slip on the tie rod though.
Kit is on the way! Great service so far from RR. Shipped same day that the payment was made.
Ended up being very inexpensive with the core exchange.
Question regarding clamps. I picked up a synergy (model #8003) for cheap.
I noticed on their website afterwards it states "not intended for use with hydro assist"
Are any of you running one? It looks the exact same as the others, size and type of metal.
Was just going to weld the tabs to the clamp opposed to using a bolt.
**It looks like they made two clamps previously and discontinued one?
***Looks like they did make two clamps - the hydro one is discontinued.
I'll add this for reference - the new clamp isn't rated for hydro because there is no welded bung.
The threads are not long enough - however the clamp is actually the same.
So if you weld the hydro tabs to the clamp - or add a bung - there's no issue using it.
Ordered my kit today from RR.
What are most of you using for the tie rod clamp?
I'm using a Synergy tie rod. I see PSC makes one - as does Synergy.
Any reason not to just weld the tabs to the tie rod?
Do I NEED the low misalignment spacers right away?
Coolers - Do you run one? Are they really needed?
Pretty happy to finally get this set up to cure my steering woes.
Driving anything high traction is brutal and requires a lot of wheelspin to let me turn - which usually leads to broken shit.
I guess it’s too late now but I installed the PSC kit with Box/pump/res/ram, and added a cooler. When I installed the system i installed a dual pass aluminum heat sink cooler. the system ran like shit and the temps were stupid high, I couldn’t bleed the system properly because the cooler trapped air in itself. I removed it and ran w/o a cooler for about a month, the res was really hot to the touch after running for several minutes but the temps were lower than when I had the heat sink cooler. so I added a radiator style cooler and an aux fan which did bring down the temps. I cannot say the system ran better or worse with or without the radiator style cooler and fan. I later learned that a hydro systems run hot and that it is normal and the temps I was experiencing when I ran it for a brief period without any cooler were not abnormally high. I would swap out your synergy tierod to something that doesn’t flop w/o spacers that you need to buy at an additional cost. I am running the PSC clamp and have not had an issue with it slipping.
where did you place the cooler?
to properly bleed the dual pass cooler, you need to have the end with the hoses higher than the opposite end while bleeding the system.
I have mine on the front of the radiator along bottom rail. I was able to raise the hose end and let the other end hang down in front while I bled it.
I can tell you from experience the radiator style cooler blocks air flow (worse if using a dual setup) and will begin to leak at the hose fitting joints. I'm guessing it's the line pressure that weakens them. Haven't had any issue since changing out to the heat sink style.
I ran one on a synergy tie rod, only issue I had was the synergy tie rod is relatively straight and gets very close to the diff cover when turning.
Once I added the ram assist, the flop was causing the ram to hit the diff cover on the PR44.
Once you added the boots I'm assuming that was resolved?
Mine hits right now (steering stabilizer) so I think I'm going to weld the hydro tabs further left on the bracket.
Did you use the standard barbed fittings on the cooler? I'd be worried they wouldn't be able to hold the pressure.
Kit arrived today.
Everything was packaged well - the steering box is double ported for a V8 conversion as well (future upgrade). Lines included are really nice - 4800psi rated.
Will be doing the install/first impressions tomorrow.
Sent from my ONEPLUS A3000 using WAYALIFE mobile app
For now yes, it's easy enough to add one in the future if it ever becomes a problem.
My steering doesn't overheat at the moment so I'm assuming with the assist it will generate less heat than before.
