BABOOZLE
That’s going to look so good when it’s complete [emoji106]
I sure hope so!
Crazy old beast! Are we going to see some trail shots soon?
Finally got the grille and hood on. Definitely motivating seeing it come together. View attachment 316270
Now I’m mocking up some sliders klungly built for another project. Should be pretty sweet when I’m done. View attachment 316272
It's looking good! Glad to see ou can open you garage door again [emoji23]
 I need to set the pinion angle before I weld the perches but I needed weight on the frame to ensure it was all going to work out. So I shifted to building a gas tank mount and mounting the flatbed.
 I need to set the pinion angle before I weld the perches but I needed weight on the frame to ensure it was all going to work out. So I shifted to building a gas tank mount and mounting the flatbed.  Decided to mount it forward of the axle to keep it out of the way of any rocks and stuff. It sits high enough in the frame that it won’t come close to the DS. I will still build some sort of skid plate.
