Looks good. How's the condition of the leaf spring bushings?
They are dry rotted. I’m debating throughout these back on until I get the jeep finished and then order new ones or just order new ones now.
Oh and must be Jeeps have always had a lean. My passenger side had a spacer in it.
You can get replacement bushings for cheap or replace them with polyurethane. That block may have come from the factory to help compensate for driver weight.
Yeah I’ve seen the bushings. Might do that too. The leafs look in pretty good shape. I guess they won’t be that springy since I’m pretty sure this thing has about 3.5” of travel total. Lol
It was on my passenger sideeveryone else’s driver side. Lol
They're a bitch to get out, but certainly cheaper than new springs.
Leaf spring bushings $20
New shop press $150
Two new leafs - $125
Guess I’ll get the bushings. Lol
I’ll see if I can dig up one of Les’s old hats. Hang it from your mirror or something. lol
Old spring bushings can be a PIA. Start soaking in penetrant. If you soak em good I’ve had decent luck with a couple whacks using a punch and dead blow.
She worked for the post office? Hell yeah I’d put that in the jeep.
I've had so many on older vehicles that required a torch and air hammer. Hope yours go smoother.
Never mind your right. Forgot spring under. :crazyeyes:
The passenger side was leaning so I was debating taking it out. Although I don’t know if it was still leaning when I was sitting in it.
Maybe but fuck that! I’d rather buy a press.
Before you remove anything, replace the bushings on the springs and shackles. I had a bad lean on Jane and to the point where I thought her frame might be twisted. I replaced the bushings and she sat level again.
A press is always a great thing to have and they're cheap at HF but you'll most likely find that it'll just press out the rotted out rubber and leave the metal collar frozen to the leaf. I've found it necessary to use an air hammer to get them out.
