fiend
My eye was right on with the rear pinion angle
Not as close on the front
But I checked and this number is the same as the pinion angle
And this number is the same as on top of the knuckle and a lot easier to get to
The only thing I don’t like is I had the axle centered on the bump stops before I had to shorten the upper arms, now it is not centered anymore
Do you have adjustable front LCAs? If so, you can lengthen both uppers and lowers to push he axle forward a bit while maintaining your pinion and caster angles.
