-AINOKEA-
There are no cliffs in Indiana. Lol
So... fire it is then. Lol. All jokes aside, I really hope you can work it out. Good luck
.... Honestly I would pull one fuse at a time to try an isolate which circuit the issue is occurring within.
if it were me, i'd pull the battery out and look for any wires that may have gotten broken, loose or corroded downline from the battery.
are you sure all the thinner wires got connected back to the battery? I'll need to get a pic of my 2010 but is I recall there are a couple of red and black smaller guage wires that are OEM
did you check the multiswitches on the steering? (cruise control and turn signal switches)
Hey Mark-I can think of a couple other shops in town you may want to go to before the dealerships. I’ve had really good luck with a couple
Sounds like a short somewhere. Any corrosion in the harness when you replaced the tipm? Any recent high water offroading? Honestly I would pull one fuse at a time to try an isolate which circuit the issue is occurring within.
Whatever the fuse is protecting will stop working. The other symptoms that aren't related to that fuse(whichever fuse you pull) will hopefully stop happening at the same time.Does this imply if I pull the correct fuse the symptoms will go away? The wipers would stop when I pulled the wiper fuse but that didn’t tell me anything I don’t think
If an electrical short is causing the issues and you eliminate the short by pulling a fuse then yes the other symptoms may disappear. It's not a full proof way to diagnose the issue but it's easy enough to do and could save a bunch of time.I know I’m retarded electrically but if my dash is dead and turn signals don’t work will that all start working possibly if I pull the correct fuse? Maybe my clue is the headlights stuck on?
I may be wrong, but I think all that shit is driven by the CANBUS so if there is a wire or component that is grounded or loose, it would cause gremlins like you're experiencing. Not sure if pulling fuses would help track it, but it might.
Yes. The clockspring relays information back to the computer via CANBUS.Is the can bus at all related to the clock spring they replaced on the recall?
headlights won't turn off? the headlight switch is a multi-switch and all run thru the clock spring. very possible the clock spring is bad again or the headlight multi-switch is bad
wondering if the dash is grounded properly, take some wire, find a good spot on the dash to ground to and run it direct to the battery negative.
I didn't read back far enough but are there any codes?
I hope the clock spring is bad again, at least that should be under warranty
I hopes so for your sake, when will you be taking it in?
