Napalm
I have a question for you on your EVO leveling kit? Did you install this similar to Eddies budget boost write up or did you just remove the old springs and install the new ones in the front? I am just trying to figure out what I need to do when i order mine here shortly.
Thanks
It's a similar install but all you have to do is remove the front wheels, release the bottom bolt of the shock and the brake line bracket and sway bar and you have enough room to droop your axle to remove the front spring and put in a new one. The rear is the same except you a putting a spring spacer on top of the spring. It's a very simple install that only took us about 3 hours, and an alignment was not needed.
