Thanks for the feedback. I tossed the OEM arms a long time ago lol. I'll check my brake lines like you said. I did just raise the brackets up an inch so maybe I messed up.
Responding to earlier comments...
Yes, the driveshaft clearance is from stuff, not droop....but the trackbar length will be a balancing act between that and this right arm clearance.
Also, MC does not relocate the shock mounts unless you are using their 6 pack shocks. The specifically state NOT to use rock star skids with their lifts on their website. I knew this going in but figured I would just need to add a bit of bumpstop (which I did).
Finally, I havent any issues I notice while wheeling so I wouldnt have found this unless I was inspecting it on an RTI ramp. If you have the same arms and rock stars and the means to drive your passenger side up something and verify, I'd love to hear what you find.
As an fyi, when Im up on jack stands with the coils off, I can cycle the rear fully with no control arm interference. Seems like the opposing front corner needs to be loaded also to make this happen. Just weird.
