jesse3638
At my old job we had a 2012 Ram 2500. I took it in because there was a regen reprogram TSB. The CEL had just come on too. The CEL was triggered by the air filter nearly being sucked into the motor. Someone had replaced it with a Fram and they don't allow enough air to pass through it. The service tech explained that all the filters need to MOPAR otherwise your warranty will be voided should something relating to a filter failure occur. She also explained that they had recently had to replace a motor after it sucked portions of the air filter element into it causing it to "blow up". The owner was on the hook for a $25k repair as it was an aftermarket filter.One of the fuel filters is almost $200 by itself. But it's the one that doesn't have to be changed every time
