Armydog
Correct!
:beer:
Just ordered the RS9000s. Thanks for the advice, they should be here on Tuesday. AND $100 rebate!!!! You da bomb!!!!!!!
Sent from my iPad using WAYALIFE mobile app.......
Correct!
:beer:
Rancho
If I were to get the 3" trail kit with the rs9000's would I need the x-over exhaust kit if I change the driveshaft? Also which driveshaft would you recommend? Thanks
Rancho, would the 2" sport kit provide enough room for 35"s on a jku? If so, would there be any rub on articulation with trimmed fenders?
From what I've read, you can run stock height and clear 35s with trimmed fenders. You need proper back spacing though, other wise you'll rub at full steer.
Sent from my SCH-I535 using WAYALIFE mobile app
I have a Rancho 4" long arm installed in my 2013 JKU.
It does have a softer side of coils and shocks (9000) which i liked.
Now, i run rancho long arms with King coilover setup Ditching rancho coils and shocks for bit more articulation.
The front seems to articulate very good but rear will Bind with the shocks i have. You will need to mod rear upper arm a bit to get a full extension out of it.
if you are not going to do some major coilover mods in the future i sure would recommand Rancho kits.
Very smooth ride and good for off road too.
here is the rancho long arm installed w/ 40" tires d60 axles.
Well, since I started this thread I guess I should post a follow-up. I ended up going with the 3" Sport kit with 9000XLs. With the rebate and a good sale price on both the kit and the shocks it ended up being around $600 total.
Before:
After:
Almost exactly 3" gain. And it rides great! I only had one issue installing it and that was the lower sleeve of the front shocks were too wide for the mounts. We had to pry open the mounts and then bend them around the shock to get them secured.
It worked out in the end, not a huge deal, but a bit disappointing when compared to the ease of the rest of the install. I would definitely reccomend this kit to anyone else looking for a decent lift at a reasonable price.
Hopefully Rancho can help. Is there something you would recommend to protect the adjustment knob. I keep breaking the rears on rocks.
Thanks,
Chris
Just turn them around so they face the front. That's what everyone here told me. Make it more difficult to adjust, but a least the knob is still there to adjust it. I did the front also.
I do remember seeing that. Have you turned yours around?
Sure did. Only had to unbolt the bottom bolts. And spin them around. I have the rear set at 5 and the front at 4. I'm still trying to find that sweet spot. I does make it more difficult to adjust though.
