Couldn't Quite Get There
Holy thread revival, Batman!
So, after wading through this thread I figured I'd try and help out here. And, I was nearly able to, but not quite. I'll share what I ended up with anyway.
I have a 2016 JKU with the tow package and 35's and the 6-Pak suspension. I wanted to see how far I could get the rear end to stuff/droop. Unfortunately the terrain in my front yard wouldn't allow me to get the rear suspension drooped all the way. For the point I'm at (which is a long way from full extension/compression) the sway bar is not a limiting factor at all:
Here's the jeep flexed out as much as I could get it with the terrain I had to hand. This is by no means full flex.
Here's the rear shock. There's still plenty of shock and spring compression available - I couldn't get it to fully stuff because there wasn't a severe enough angle. I think I need to find a ramp to drive up.
When I'm able to find the right terrain to get the rear axle at full droop I'll update the thread - and then everyone will know (at least for this setup) if the rear sway bar limits the travel of the suspension (which, for the record, I don't believe it does).
And, to clarify something about this suspension for people that are not familiar with it - there is more up-travel than a standard shock. Therefore, even with a 3.5" lift I am able to run 2" of bump stop at the front (with minor rubbing on the top of the plastic fender) and 1" at the rear (with no rubbing). I'm not saying this is better or worse than other suspension systems out there - merely that it is set up differently from a standard shock. As you can see from the (sideways) picture below - I'm on the front bump stop and still have some spring compression available.
