RubiCAT Gettin EVO'd UP!!
JJM
Im not sure if this has been asked or not but what is it that kept you guys from doing the EVO Lever on Rubicat?
bl17z90
Rubicat has the bolt on system. The lever is used with the double throw down system. Double throwdown has a different mount up front as well.
cozdude
Guy with a Red 2-Door
i think it was to show how capable the bolt on coilovers are. they are as capable as the lever but since they already had the lever on Moby i think they just wanted a different set up.
you can get a single coilover with the evolever. it isnt just for double throw down
edit- nevermind im an idiot. yes the evolover is just for the DTD
OverlanderJK
Resident Smartass
No you can run the lever with the single throw down. One coilover and no bypass.
Oh, believe me, we wanted to install an EVO Lever and DTD but at the time, the bolt on coil over kit had just come out and being that it was new, we wanted to test it out just so that we would have first hand experience with it. Having said that, we're ready to install Moby's old PR 60 rear axle and will install an EVO Lever at the same time. For now, we'll most likely just run it with single coil overs and add on bypass shocks in the future.
Krieger
So when you install the rear leveler does all the rear high clearance brackets need to be removed?
And with running a single bypass shock
Will that increase the open desert speeds or will it be about the same as the bolt on setup.
bl17z90
So will the evo lever allow more flex than the standard bolt on mounts? Will it improve high speed desert driving?
