tonytony9
No, it wont be a problem with the battery. If you play it a lot without the vehicle running, it will kill the battery, just like any other vehicle.
Run a single power, and go to a distribution block. Fuse power wire at battery, and a fused distribution block for each power wire to amp.
You dont need 1/0 for those amps. 4ga is plenty, as is 8ga from distribution to amps. Neither amp requires a ton of power.
You can also do a ground distribution block, or just ground to a good spot for each amp.
Cap will be a waste of time and money. Set your gains appropriately. They are not volume knobs.
If you need any install pieces, let me know. I have quite a bit hanging out in the garage.
^^^^^this is great thank you, I'll message you
