MTG
Never! I wouldn't put one on even if it was given to me wrapped in $100 bills.
*sadly he unwraps the $100 bills from his Christmas present he had planned to give away for months*
Any clue what kind of temps can be expected under the hood?
The box I am looking at is good to 248 degrees. Not sure if that is sufficient but I would think it should be.
Engine bay temps will be right around there if not slightly lower
That concerns me a bit. I don’t need the poly box melting.
This is what I was looking at:
https://www.polycase.com/sg-14
I think you'll be fine. I'll take some readings tomorrow, but if you think about it, you already have fuses and plastic under the hood that are likely still in tact and not melted.
The engine cooling system should stay below 210* and the engine itself shouldn't be much above that. The exhaust is hotter, but doesn't take up much room in the engine bay. I would be surprised with the volume of air and lack of positive sealing in the compartment if it even reached 200*
That’s what I was thinking but I’d love to see some measurements if you have time. Thank you. :beer:
I’m trying to avoid the rat’s nest to the battery and couldn’t get myself to drop the coin on one of the aftermarket solutions. So, I decided to try to make something myself.
I went with the very nicely packaged switch-pros system. Love how compact it is with minimal wires and small foot-print...It's expensive to be cheap!![]()
