The build of Jenny
RockinAZJK
Update:
Being right after the holidays it was rather difficult to find the heim joint in question. Tracked one down at a custom race shop and should be installing today!
RockinAZJK
About a week and a half ago my Jeep family grew when my girlfriend acquired an 08 sport. All stock except for newer rubicon wheels and newer windshield with the Jeep in the corner. IMG_1484270885.779561.jpg
JK_Dave
Update:
Did that fix it? I'm pretty sure I've heard other people discourage others from using heim joints on a daily driver just because they do require a lot more maintenance than other joints. Can't remember if it was Mel Wade or someone else.
Edit: Ruff Stuff Specialties carries heim joints that might work for you in the future.
RockinAZJK
I knew ruff stuff would have them but I was trying to avoid having to order it.
As far as this being this fix am I not sure yet. We finally just got the heim out last night. It took a guy about twice my size along with myself, a lot of pb blaster, a bench vise, A LOT of heat, and about 5 feet of cheater bar and we still didn't think we were going to get it. After every turn we had to stop and soak it and heat it again.
RockinAZJK
So now that the joint is out I needed to let the bar sit overnight in vinegar to get the rust out of the threads. Will be scrubbing and installing tonight and will find out this evening if that fixes it or not
RockinAZJK
So as some of you read, I had ordered a crawler conceptz skinny front bumper. They screwed me around for about 3 weeks on when it would be ready to ship. Finally cancelled the order and went with the Evo quarter pounder!
RockinAZJK
In the bumper I have a superwinch 9000 mounted. The bumper winch combo weighs around 200lbs easily. Unfortunately I was doing all of the work alone. Luckily I have access to forklifts when I work at my office... IMG_1485044107.624636.jpg
RockinAZJK
Update on the dw issue:
I still have not been able to get rid of this damn death wobble. I found that the frame side holes for my track bar were wallowed out. Had some steel washer cut and welded. That hole is now tighter than ever.
I believe the track bar was the cause, and now my tie rod ends are toast because of the wobble and have become the new cause... trying to replace those now if I can find the ends...
Randy Tadevich
