jdofmemi
That was my only concern with these wheels. What tires are you running? Did you have to use the spacers between the wheel and ring?
I'm running 37-13.50 STT Pros. I got them mounted without spacers, but I probably should have went with the spacers. The bead is really thick on these tires.
It took a lot of times around to get them torqued, and when they were finally there, the ring has a slight deflection. It is touching the wheel, but it seems to be concave. Not hardly enough to tell, but I'm sure the spacer would have made it sit better.
The picture don't really show it well. I could not find an angle that would show any better.
