boardsurfer
Good day today! The Outlaw rides again!
Started early this morning wrapping up the details on the transfer case. Basically double check everything is tight, connect the signal plug, breather and shifter cable.
Then Slimebones and I started on the drive shafts. I went with Adams 1350s. Pretty textbook install if not awkward trying to hold it in place to get the first few bolts started. They are not light.
After that we touched everything on the rear axle that we had left loose before, waiting for it to be down on its own weight. Satisfied that everything was torqued, we started on the fluids. Slimebones filled the transfer case and made a huge mess , I filled the rear diff and gained the privilege of smelling like gym socks and stale fritos. Gear oil is some dank shit. :icon_crazy:
Then we climbed in and took another tentative trip around the block. Traction control light was on. Turned itself off, then came on again a minute later. Odd. Then I realized I hadnt done any of the programing for the gears, tires, and transfer case. Fixed all that, went around the block, still with the light on the dash.
Doug set to looking at the speed sensors on the rear and discovered one of them loose (the one I did, of course) Pulled the plug, took the sensor out (that was a fight) cleaned everything off really well and put it back together again. The problem was that it was just really dirty and when I put it together, it never really made a solid contact. After cleaning it out really well, we had a successful trip around the block.
Finally, we did a quick and dirty alignment and called it a day.
