That is the coolest/oddest drill bit I have ever seen, but that sure looks like the best option for the drilling of the upper plate, way easier and precise than what I did for sure. I wonder if my brake bolts are one right, but I guess they wouldnt work if not correct?
Looking good man, this will deff help out more guys installing these at home.
Good question on the bolt. I would assume not though, if they weren't lined up.
I hope so, just like your tip to remove the battery before cutting into the passenger side plastic on the 012 and up models.
I don't believe they need to be aligned. There is a recess around them to allow fluid flow.
Yep. There is. They were snug, not too tight with aligning so I continued. I figured if it was that big of a deal, there would already be a mark on them.
Why were they that snug you think? The brake line just that different? You should not have to line up a banjo bolt.
FYI, your inbox is full. So what size do the nutsert holes need to be drilled to and what size for the brake lights? There are roto cut sets on eBay that are only 3/8" for about $40.
Sorry, I didn't see this sooner. Work has kept me busy this year. Ya, that 3/8 roto cut set is the one I have. It works great. I drill a 1/8" pilot hole once I get the skins where I want them. Then that pilot is the centering hole for the roto cut drill. I just put my rear skins on this week using this tool.View attachment 185045
Looks great dude. Are you going to paint them?
Yeah I put mine on this week too. I ended up buying and using this tool also. I got the skins lined up, used a transfer punch to perfectly mark the center, and then drilled the 1/8" pilot. The rotokut was amazing and worked flawlessly so thanks for the recommendation. The only problem I found was that it actually cut the hole so close to .375 that I had to follow it up with a 25/64" in order to get the nutsert to go in. Now that I've used it I can say theres no going back, it really is the best and fastest way to cut those holes. Takes longer to drill the pilot hole than it does the 3/8".
