I would try turning in the joint a few turns first.
Hey man. How are you? I've tried that. I'm still off that much. Did you end up getting one?
With the drivers top hinge drilled and tightened in place and the passenger two hinges drilled and tightened in place, I'm off a little. View attachment 185066
I haven't drilled the driver bottom yet. I'm thinking I'm going to oblong the passenger holes on the skins over so my hinge hole will line up. Thoughts?View attachment 185067
You think you could anchor ratchet straps to the passenger side of the carrier and pull it in enough line up? Maybe with a little heat it could be convinced.
Good thought. It's worth a try
it turned out ok.
I even mocked up a new license plate holder that will sit above my roto-pax mount. Third brake light, lic plate light and backup camera above the lic plate. I've got everything wired up to include extra backup/dust lights on top of my rear fascia too. Off to powder coat this week. Things are finally coming together.Finally time for the first oil change. While I was under there I got my first EVO skid installed. View attachment 185587
How did that work out for you? I had to slot one end with a round file about half a hole to get mine to work. Sure glad I put it on there, especially since I already put a little love tap my pan already.
What did you end up going with as far a GPS security device........I remember you mentioning SPOT as one you may go with........Just curious if that is what you went with and how it's been working for you.
~Woodrow~
Yes. I did go with SPOT. I love it. My 17 yr old daughter (this is her daily driver for now) can't figure out how I know where she is......:cheesy::cheesy:
Well, I started out planning on installing EVO Rock skins. I've already drilled and put the nutzerts in. Then I had EVO Rock sliders to weld on. I kind of changed my mind and decided for the next year or so I would run Rock Slide Eng. step sliders. They took my EVO skins and drilled a custom set up step sliders to match the drill holes on them. I pick them up tomorrow.View attachment 185955
