Goven your recent string of luck, I'd skip plan B, because it would most likely result in setting fire to you instead.I’ll check it when I have time, and hopefully warmth. Or plan B
Right... blower motor fixed itself after a pothole. So either sticky motor or loose wires. Either way not digging into it in the cold unless I have to, there’s plenty of potholes around I can refix it with if I have to.
Sent from my iPhone using WAYALIFE mobile appView attachment 289143
That picture is soooo true.Right... blower motor fixed itself after a pothole. So either sticky motor or loose wires. Either way not digging into it in the cold unless I have to, there’s plenty of potholes around I can refix it with if I have to.
Lol. Glad you didn't have to spend any time or money on it.
Still trying to get the OBD to go ready for the O2 and EVAP, so this thing can get througb emissions testing in TN. 1 week, 200 miles and counting.
I've followed the Chrysler drive cycle for these two, and that didn't ready up the OBD. So any input is welcome
Note to self - don't disconnect the battery when working out of state.
Sent from my SM-G920P using WAYALIFE mobile app
Clunking from my rear MC trac bar. Seemed to strip the threads out, because the jam but was not tight enough to the bar. (Disclaimer; I check all the jam nuts during reg. maintenance, however, the jam nut is seized up, therefore I thought it was tight...) Wasn’t until I starting hearing a clunk when I make sharp turns, or swerving back and forth. New MC trac bar is on the way from MetalCloak.
I found pieces of my Teraflex budget boost in the driveway. Upon inspection the whole spacer on the passenger side is gone. Seems to be a thing and Teraflex will be sending a replacement. Any seasoned advice or input is appreciated.
My Jeep had Teraflex spacers on it when I bought it. You can tell they are deteriorated. Just hoping they hold up until I finally get the rest of the parts to go with the 3" lift coils that are sitting on a shelf in the shop.Seriously, how do you F’k up a spacer??? I have some Teraflex spacers, and have had no problems, but I’ll be damned if I would buy them again.
Lol. Everything other than the coils.
Jk blower not working for about 30 seconds after startup. Light on knob flashed
