wjtstudios
Sweet. Thank you!
No worries, let me know if you need anything else as you get further into it.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Sweet. Thank you!
Yes I do and I was wondering the same thing as I walked out to bolt it up...haha. Fortunately the only pain in the ass was bolting the compressor to the mount. Per EVO's instructions the bolts are to be installed from the bottom up. Of course the arb bolts are too long and had to be cut. Also there is no way to get the 4mm Allen wrench onto the bolts to tighten thd compressor up after rotating it. I tried cutting down the wrench but didn't cut if shorf enough.. I just used needle nose pliers on the outside of them instead. Other than that it bolted up to the firewall on rhd mount no problem.
Yeah after looking at wiring diagrams and reading different instructions I thought I may have figured out how to wire everything up. Then found the Switch Pros ARB pigtail and that fucked up my thinking...haha. I began to over think it and was thinking I needed this, but after reading more I think I once again have it all figured out...haha.Thanks! Been looking at this setup. I guess I’ll have to break out the needle nose vice grips! Ha!
It's done. I just need to bleed the system. Everything but the ram is installed. When the 60s show up all I need to do it hook up the ram and bleed again. I'm glad I got this done, was a little more involved than I thought, but she's done.No worries, let me know if you need anything else as you get further into it.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Today I got the front axle back in and the front coilovers mounted
(Had to take a picture with my dads busted old phone)
Yesterday I welded some Artec control arm skids on
Haha thanks! Every oil change I tell myself I need to clean it up. As you can see I still haven't done it...haha.Looks good man, nice and clean. Except the engine bay though..
Sent from my HD1905 using WAYALIFE mobile app
I spray down (lightly) and clean my engine a couple times a year, especially between the condenser and radiator. [emoji106]Brick looks just like that, to me water and electric don’t mix and with the whole fiasco a year or two ago I’m gunshy to clean it
About once a year I do that engine gunk spray foam, then it's a light rinse, haven't had any issues personally, need to do it here soon actually.Brick looks just like that, to me water and electric don’t mix and with the whole fiasco a year or two ago I’m gunshy to clean it
It’s a jeep not a hot rod. I’ve never gone to a Jeep meet and seen someone “hey, pop the hood, let me see that mini van engine with that sexy clean plastic cover!”
It’s suppose to be dirty
You can do the same thing with switchpros.Any thoughts on this?
https://www.xtremediesel.com/anzo-8...rSbXBQXFK-o6shY2ub_hWC2bbY0kNFbkaAud7EALw_wcB
Sent from my moto g(7) power using WAYALIFE mobile app
