jesse3638
I was going to say the same thing. I've yet to connect the app to mess with it.You can do the same thing with switchpros.
I love mine use it all the time.I was going to say the same thing. I've yet to connect the app to mess with it.
They are pricey aren't they?You can do the same thing with switchpros.
Just got my compressor installed. Just waiting on my switch pros to show up so I can figure out how to wire and plumb it all. I hate electrical work. Thanks again Bubba. What type of fittings is everyone using? In case I want to get 90°'s or anything else. Also what is a good setup for airing up? Still need to get all that stuff. Bubba I hope your listening...haha.View attachment 356873
Yes, both worth the money. Solid sate electronics that protect the battery and power output is worth it.
Thanks for the insight. I ran a 6' braided stainless hose with flared connections. No 90's. The push connections always made me nervous. Also trying to find a place to run plastic air line where it won't hit the exhaust or snag was concerning to me as well.No experience with this compressor specifically but I’m a truck and coach technician so I do have some experience with air systems. Save yourself headaches and do NOT use push connect fittings. Use good old fashioned brass fittings. Also try not to use 90* fittings unless you absolutely have to. A 90 adds the equivalent of 7’ of air line. The less bends and restrictions the better for flow.
Yeah sure I could have mounted rocker switches and ran relays and wires, but this is so simple and clean. Plus its really simple to install. Additionally Bubba made ordering everything very easy.Yes, both worth the money. Solid sate electronics that protect the battery and power output is worth it.
Since I have everything ripped off easy to give you a couple pictures for the plastic line.Thanks for the insight. I ran a 6' braided stainless hose with flared connections. No 90's. The push connections always made me nervous. Also trying to find a place to run plastic air line where it won't hit the exhaust or snag was concerning to me as well.Yeah sure I could have mounted rocker switches and ran relays and wires, but this is so simple and clean. Plus its really simple to install. Additionally Bubba made ordering everything very easy.
Thanks for posting. Where did you put your locker solenoid? I noticed the line runs directly from the manifold.One more......View attachment 357093
The solenoid is there it's bolted underneath that manifold.Thanks for posting. Where did you put your locker solenoid? I noticed the line runs directly from the manifold.
Edit: Never mind I see its rotated down.
I just put in a1350 front and mine has a flange. In talking to my drive line guy he said when going to a 1350 it'd have to use a flange instead of a yoke. The flange and yoke actually are the same length. My driveline guy measured them. I do have a manual so I don't have that cooler. Also I noticed it looks like your bolts ar going through the flange and threading into the drive shaft. Thats how mine was initially and the bolt heads were making contact with the 4wd shift linkage in 2H. I had to have the flange on the DS drilled out and thread the bolts into the flange. May want to look into thatTried to mount my new front driveshaft but its making contact with the cooler looking thing on the side of the transmission, have to wait for the driveline shop to open up on Monday to see what they can do. I looked at all of the aftermarket driveshafts I could find (JE REEL, T. W.'s, Adam's, G2, and Spicer) and they all use a yoke at the T-case instead of a flange, mine uses a long flange. Hopefully the driveline shop will help me out...
On a better note I got to take the jeep for a test drive (RWD only) and break in the new 4.88's and EVO suspension. :rock:
