Swapped all my grease zerks out today with the low clearance ones, even on the upper ball joints.
Is it just me or are those low clearance zerks easier to get grease in? Half the time with standard zerks I'm squeezing the living shit outta the gun handle only to have the gun splooge the damn grease everywhere but into the zerk. And that's while holding the hose into the zerk. I'm tempted to change all mine out.
Sent from my VS985 4G using WAYALIFE mobile app
Exactly why we bought it. That was us one day. Luckily when we ran into it, we turned around and were able to get home. Made me think that it would be a good idea to carry one.
What you might be encountering is that your standard zerks are bottoming out and that can make it difficult to near impossible to get grease in.
Huh, never thought of that. Might need to look at tbat. Thx!
I had this same issue! I just chalked it up to joints not needing grease :idontknow:
so should I back out the zerks maybe 1/8-1/4 turn and give it another shot? or do we need to replace the fittings?
That's where I would start. If that doesn't work, remove the zerk, clean it out and verify that grease can pass through it. If all is good there, you may need to use a pistol with a higher psi to push past the dried and crusty grease or, pull your control arm one end at a time to work the joint around manually to help free things up.
Great idea on the zerks.
Great info! I'll give this a go next time I'm under the jeep :thumb:
sorry for the thread jack WJCO
