Nice! Only thing missing are some coil overs to complete the color match.
King Blue would match up perfectly!
That thought so keeps entering my mind.....
My first post on this forum. Is it possible to power the Arb single compressor using the JL aux #3 or #4 since they are 15amp? Switch 1 and 2 are already taken with lighting.
Awesome! Happy to hear you like the ACM. Good luck with the installI recently order this bracket and can't wait to install it during the weekend.
I think this is a perfect location for a single compressor; thanks Eddie for making great products!
Awesome! Happy to hear you like the ACM. Good luck with the install![]()
Awesome! Glad to hear it worked out well for you!I finally had the time to install my compressor with the ACM and couldn’t be happier!
FYI, I have a EU spec (Left Hand Drive) JLUR with the 2.2 Ecodiesel and it fits like a glove
(Just in case anyone ask you if its compatible with this engine)
I just installed one on Pippi, our 2021 JL Sport with a manual and found that Jeep changed the location of the clutch slave plumbing. Needless to say, the ACM now bolts right up and without any issues.Anyone have experience with installing the bracket on a Manual 21 JLU?
Nicely done my friend! Now all we gotta do is get you out on the trail and find a reason to use itOk just got done doing this. Took a little longer than I thought, but it came out great!
Thanks for the write up Eddie!!
All mounted with air line wrapped in heat protection. View attachment 386059
air chuck is in front of sway bar.
What year and what engine size? I don't recall having an o2 sensor wire there.Nice product, great customer support!
Ran into a smallish issue with my install. The "Oxygen"(?) sensor cable was in the way. Very short cable, with little wiggle room, but think I made it work. Though with the heat shield, I'll pull my fender in 6 months or so and see if it's digging into the sheathing. I can't edit the picture, but it's the grey cable, without the aluminum protection. I tried installing the bracket with the cable directly behind the install, but without carving out some of the heat shield, the nuts wouldn't fit on the studs.
I put mine on a 3.6. But my wife has the 2.0 (2020). I'll look later and see if that wire is there.2019 JLU, 4 banger.
Not sure if it's an oxygen sensor, looks like one though.
Gonna edit my profile now.
