It's time to open up those MoTech boxes and see what's inside!
Here is a pic of all the parts from the MoTech Basic Kit that we have received so far (not including the heavy duty radiator).
MoTech Basic Kit
- Frame Mounts
- JK to LS wiring harness with power distribution center PDC, supports AFM/DOD and VVT engines
- Harmonic balancer set, includes new bolt
- P/S mount kit, fits your JK P/S pump to the LS engine
- Alternator mount kit, fits your JK alternator to the LS engine
- A/C compressor mount kit, fits your JK A/C compressor to the LS engine
- Aluminum expansion bottle and mount
- Serpentine belt 6K1015
- Accelerator pedal and mount
- Transmission mount set for the 6L80 transmission
- Transmission shift cable mount and lever
- Air intake kit (Air Filter not included)
- Emissions kit - includes fuel tank pressure sensor, EVAP vent solenoid, hose and hardware
Here are a few close-up pics of the parts:
Frame Mounts
Harmonic balancer set and Serpentine belt 6K1015
P/S mount kit
Air intake kit
There are a few things we will need to remove from Moby and our LS engine to send to MoTech to be reprogrammed and then we will be able to start the install process.
