ATX Slabs: Lets see them!
DA RUNT
Yes, that was EVO1's old stock dash in 2010, customized on the passenger side for the Lowrance Chart Plotter/GPS. This was done for the first year it was raced in the King Of The Hammers.
Niiiice, at first I thought you had a cisco phone in the dash....... ok I need to get out of the office more :doh:
dillard09
I'm going to revive this old thread. So for the guys that have the slabs, do any of you run spacers? I know that it will add stress but I rub on passenger side shocks at compression an a little turn. So dilemma is run spacers with added stress or rub on my triple bypass? What would you do?
Jtmw
I think i would cry if i looked under and saw that. I'm running just CO and have spacers on mine. Granted not Slabs but it would take the slightest hint of that and I would have spacers overnighted.
dillard09
I hear. I might have said a curse word or two! But I have spacers and new King stickers but is the added stress on axle components better or worse than some rubbing on the Kings. I know that if something happens to the shocks I can make it home but if the added stress blows a unit bearing, ball joints or something I might be walking.
Irish JK
I had run 1.5" spacers with my slabs. A bit more wear on joints etc but it will be fine. Just have to be a little bit more aware of brake calipers being exposed.
dillard09
I didn't think about the brakes being exposed. Thanks for that. If i have the Slabs and spacers on and something wears out or breaks and I'm not on the trail I think the repair of that is cheaper than ripping the compression adjustment off of my triple bypass. I'm just trying to make these d44s last about a year till I have enough saved up for the 60/80 combo, 40s, and new 8 lug slabs.
GoldenJK
Ordered slabs and should be in next week. I like the black look and plan to paint the rock rings but have a question. Should I paint the entire ring or just the visible side? Would painting the inside impact the seal with the tire?
Speedy_RCW
The paint on the inside of the ring won't affect the seal. I only painted what was visible because I used touch up paint which wasn't exactly cheap so it's really just your preference.
Havoc40
I only painted the visible side as well. Mostly because it was easier, and I didn't see a reason to paint the inside. Love the look!
Best close up I have
DWiggles
My contibution to the slabs thread
Havoc40
Those look awesome. What paint brand and color did you use?
Thanks! I used VHT graphite and I think Duplicolor matte clear (I'll have to check the extra can I bought). The 1st time I painted them, I didn't use a clear coat. Between cleaners and mud they stained pretty easily.
Congrats on the Slabs, you'll really like them!
M_Savage
I just got w set and all ready for air.
Anybody know if an ARB twin air compressor can generate enough pressure to set the bead??
