Oso Build Thread
dchew
Yesterday we finished the EVO Protek skids. The oil pan and tranny skids fit fine, but the third piece that protects the exhaust crossover pipe does not fit with long arms. So we cut it to fit.
Definitely better than the nothing but not as good as the real thing.
Prime8
Do you have the Double D long arms? My Protek skids are coming in this week. Apparently I will be doing some cutting too..
dchew
I think the arms are the same regardless of the kit (high clearance vs DD). For all i know they have something specifically for these arms. Certainly Rubicat has this system, but that may have been an EVO special.
I should have radius'd the corners more. Do that and it will be stronger. Oh wait, why am I telling that to a mechanical engineer??
Prime8
Haha, I'm a materials engineer, but my current role is failure analysis, so I know all about stress risers and failure mechanisms.
Prime8
The bummer is I had to cut off the cool part (EVO logo). But I saved it. :)
That's ok, put it somewhere where is can be seen, instead of just rusting under your rig. It's EVOs version of 'removing the tag' after purchase.
Prime8
Hey Dave, do your rear LCAs look like this? In other words, can you see two sets of threads like you can see in this picture of mine?
rtguy1
the arms are the same in both kits, and the front bracketry is the same in both kits. The high clearance kit involves removal of rear frame and axle braketry and installation of new brackets on both the axle and frame. :thumb:
looks great dchew:rock:
Prime8
That makes sense then on why his looks different!
dchew
Yeah as rtguy1 said, it's all the same except for the lower axle mounts. Makes sense that my arms are set shorter because they are a little higher.
My housings are stock, btw.
dchew
I suppose it is worth noting there is one small disadvantage of the high clearance kit besides the difficulty setting it up: the Jeep ends up about an inch higher at its lowest setting, simply because the bottom shock mount is higher.
Dave
