CrazyLarry
Also does anyone have a good starting length for me to set the Currie upper arms with factory lower and 3.5" RK coils?
Just so I'm not taking a shot in the dark first try
and advice on what I should replace my chewed away factory bump stop with?
Glad you like the arms. Everyone has their own way of installing and aligning their arms. I just did mine and it came out pretty good so I'll just tell you what worked for me
Step one with all wheels on the ground install both rear lowers one at a time. Don't tighten just get the bolts through
Step two remove both rear uppers
Step three put a floor jack under your pinion and jack your pinion up to where you want it. I set mine 1.5 degrees lower than my driveshaft. Remember the driveshaft tilts up slightly on acceleration
Step four measure the distance from the center of the mounting holes on your upper control arm mounts and set your uppers that length.
Step five install your uppers. You may have to shorten or lengthen them to get them to line up to the holes exactly. It is very important that they are set the same length.
Step six torque to spec
Step seven return your sway bar to its factory location
As for your coils touching your trackbar you may or may not have that problem with your stock lowers installed but if you do try rotating your springs. I moved my axle back 1/2 and it rubbed slightly on the trackbar but after rotating my spring they no longer rub. You have my number in the email if you need anything else
