Took a while to get in and it may not be the prettiest thing in the world but, when pickings are slim, you gotta go with what you can get your hands on. Time to replace the old factory steel tank with a big crack in it with something new and made out of plastic...
Weight saver!! Lol. I hope your sending unit matches the ohms of your gauge. I'm having a tough time getting mine to match up.
Now that you mention it, previous owner had it hooked up to an aftermarket gauge and even had another one installed like he was in the process of using it instead. Are you using resistors to help correct things?
I add 5 gallons of gas every other time I drive it.. Lol
Honestly I'm at a loss of how to make the gauge match the sending unit..
Clearly, this Jeep was made before the advent of skid plates! It's hard to imagine this one beat up strap is the only thing holding the gas tank in place :crazyeyes:
As mentioned, the previous owner installed a set of gauges and I spent some time getting them to all work including the fuel gauge which seems to be reading correctly...
:rock:
Nice work! You planning to add another strap or replace that one or is it still good?
WooHoo!! Finally got some new window whiskers installed - no more window rattle :thumb:
Spent some time cleaning up the engine. Still got a years of grease I need to scrub clean but, it's a first pass. May have to find a steam cleaner to get it good but, at least you can now see the orange/red of the valve covers.
What did you use on it? I used to use simple green back home when we would clean up old cars and it seemed to work pretty well if we let it soak for a little bit.
I used Purple Power. It's pretty toxic stuff and can be bad for paint and I typically just use it for the underside of a Jeep but, Simple Green wasn't enough to cut through the greasy mess under the hood. After a few passes with the Purple Power, I came back with some Simple Green to finish things up. I still need to work on the underside but, it's a lot better.
Gotcha. At least there isn't any rust.
Gotta love rigs out in the west - this thing is surprisingly rust free. I mean, there's a little here and there but really, not a whole lot of anything considering it's over 40 years old. The 2007 JK I bought from my friend Ken that became VENGEANCE had a ton more rust on it :crazyeyes:
