The Building of Compromise
Yep, the TMR are legit.
Cost a bit more, but IMO worth it.
My only "complaint" is that I forget to put a dab of grease on them during the winter. I get a squeak everyone once in a while.
Yep I remember being scared the door was going to fly off.
You need a long 9mm to pop out the old liner. And PB Blaster to soak the old ones a bit.
Here's a pic of the stock ones compared to the tmr liners.
Good tips. If we do the inserts, we'll go with these for sure.
And I don't mean to sound like a badass, but I didn't think the doors were that heavy and I'm a small guy. After reading all the stories of injuries and door damage, I expected the doors to be much heavier but didn't think they were that bad at all.
Do yourself a favor & pick one of these up at Home Depot/Lowes etc- they're like $5. Make putting doors on & off a breeze
Quadratec has them now also, a friend of mine and I split a kit for a 4 door since we only needed half a kit each and one tool
Yea but they are not as good. Gregmort has the qtech ones on his Jeep and his doors are all seized up and stuck in the liners after only a few months. Literally takes twenty minutes to pull them off. My tmr liners are almost two years old and still work like new.
Edit: that took embarassingly long to figure out ho to post
DO NOT GET THE QUADRATEC LINERS
Eek! I thought they were the same thing? I wonder what the difference is, I figured delrin was delrin, dangit
Edit, I had to adjust my catches or whatever they are called up due to the thickness of the bushing, is the tmr like that too?
The tmr slide right in and fit amazingly. Didn't have to touch the door pins at all.
