WJCO
Meme King
Using this write up to change out my axle shafts but have run into a little problem. The bolts that hold the axle retainer are spinning as I try to remove the nuts on the back side. I was able to get two of the four nuts off but now I’m stuck. Any ideas on what I should do now? I don’t have a welder so I can’t tack weld the bolt and I can’t get any pliers in there to hold the bolt from spinning.
Can you get a dremel in there with a cut off wheel? I'm hoping that your new axle bearing kit came with a new retainer plate.
