Been busy servicing the Jeep and installing a lift these past couple weeks.
Replaced all brake pads on my dynatrac progrips. One of the slide bolts was seized on one of my rears. Never seen that before. It was hell getting it free and I regreased all my others and apparently will be doing this every change.
Installed 32 spline rear axle shafts by revolution to fix my bent flange. Unfortunately one of the studs that secure it to the axle flange started spinning so I had to get it tack welded.
Changed oil and transmission fluid.
Installed my lift
Evo 3 inch plush coils with 1 inch spacers
Rancho 9000 shocks
Syngery front trackbar relocation bracket
Clayton offroad rear trackbar relocation bracket
Syngery brake relocation brackets
Draglink flip
All I have left is the evo rockstar skids and find a driveshaft when mine dies. Going to have c gussets and front lower control arm skids welded in a few weeks also.
I also finally found what was causing my vibrations while driving. Turns out it was 2 of my tires. I had them balanced 3 times but I noticed after replacing the shafts the driver rear was wobbling while driving. Replaced 2 tires and vibrations are all gone.
Sent from my SM-G965U using Tapatalk
