LOL - as long as it works.
So as far as having the steering wheel so far off center after hitting the wall, this leaves the steering box itself as the culprit, or whatever linkage is between the box and the steering wheel. Im not too concerned about it, but I dont know if I should be. :idontknow:
...Or maybe the threads jumped on the drag link coupler... but I just didn't notice any signs of that.
I'd put my money on this one. Did you align the clamps on the coupler properly so the bolts are perpendicular to the opening of the sleeve? If not, you can tighten the bolts all you want but the threads will slip when under stress.
Lol. Didn't realize I posted in this thread before. [emoji23]I saw what you said in the thread... after I posted here I checked.... and nope, not perpendicular. I don’t remember ever rotating them... that’s got to be it. They must have jumped. I’ll rotate it correctly tomorrow.
I still want to address the Sector shaft though. I really don’t want Hydro for 35’s... The sector shaft braces seem gimmicky and the XD big bore has been pulled from the website... so now I’m not sure what the best route is.
As much as everyone touts PSC, the Redneck Ram setup is amazing. I wish I would've gone with it sooner. Even with 35s.
Need to check this out on mine . Steering wheel alignment slips 10-20 degrees every time out
Did you ever figure this out? Same exact thing happened to me this weekend. Got off the trail and my steering wheel was at 90*. The coupler rotated just fine and I centered the wheel before heading home. I assumed the Drag link was bent as it clearly pushed up and hit the stabilizer motor ( I can see the rub marks). So today I picked up a new draglink... and it has the exact same bend. (I have a spare now :crazyeyesSo now I am paranoid the force of the hit damaged the sector shaft. Or maybe the threads jumped on the drag link coupler... but I just didn't notice any signs of that.
Are you sure it’s exactly the same bend? Did you swap it out? I bent mine at one point and you couldn’t tell without putting them side by side
That happened to me too last year after a hard hit on the trail. I figured the stock drag link was bent, and I just adjusted the coupler. When I put the lift on I replaced the draglink with a RHD. After running Dishpan, Holcomb and JB the steering was off again, maybe 45 degrees. I adjusted it before heading home. Shortly after I started getting some wobble if I hit a pothole which progressively got worse over a few weeks. I finally found just a little bit of play at the pitman end of the drag link. I ended up replacing the whole thing with a Currie DL.Did you ever figure this out? Same exact thing happened to me this weekend. Got off the trail and my steering wheel was at 90*. The coupler rotated just fine and I centered the wheel before heading home. I assumed the Drag link was bent as it clearly pushed up and hit the stabilizer motor ( I can see the rub marks). So today I picked up a new draglink... and it has the exact same bend. (I have a spare now :crazyeyesSo now I am paranoid the force of the hit damaged the sector shaft. Or maybe the threads jumped on the drag link coupler... but I just didn't notice any signs of that.
