nbunga
Nice upgrade!
Thanks guys
Nice upgrade!
Holes all reamed, drag link and tie rod installed.
Ported steering gear installed, went pretty well, just lowered it in with an electric hoist.
Anyone ever run into this issue?
I think I need to clock my pitman arm 90*, I can’t get to my steering stop going full driver before I hit the gearbox stop. That’s with the drag link adjusted all the way in. The box was used so I’m thinking the arm may have been installed 90* off. I’ll have to pick up a puller today, mine are all to big.
View attachment 349695 View attachment 349696
Do you have that much additional travel the other way? Disconnect the tie rod and see.
That’s ok. I picked one up at Napa. I had to get hydraulic hose for the ram anyway. Thanks for the offer though.
Did you get that abrasion cover like they put on backhoe lines? I think I have some still
No I forgot about that. I bet TFE or Power Components would have some if you don’t have any left.
Ok, the pitman arm was fine, I ha my tie rod adjust all the way in, every turns as it should.
Question on the ram install. When I mount it, I want the steering all the way to passenger with the cylinder fully compressed? This seems like the way it should go. View attachment 349717
Yes, but also check it at full extension on the driver side too.
Looks correct in the picture to get the tabs burned on. You can adjuster exact position on the TR mount later on.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
And this.You confirm you have your lines right going to the ram?
