JKbrick
Thanks! After I discovered I did this
Had to find a nut and some washers and get out the impact and pull the studs in place
Looks great Mark [emoji106][emoji106][emoji106] get it dirty already
I like the progress!!! Glad that press worked out too.
Sent from my SM-G965U using WAYALIFE mobile app
I bought a Lisle wheel stud installer when I was swapping out my rear axle shafts.
It wasn't the cheapest tool but made pulling studs thru easier than messing with washers/nuts
The Lisle has a bearing on the bottom that allows it to easily spin :thumb:
Everything has been checked, double checked, and dialed in. Gear break in starts tomorrow. The one and only thing I need to do is make the rear track bar 1/2” longer. Pumped to feel the difference. I told Tina it looks no different but it’s badasser [emoji23][emoji23]
As Eddie mentioned years ago with Rubicat. Regarding is the best bang for your buck. You're going to love it.Everything has been checked, double checked, and dialed in. Gear break in starts tomorrow. The one and only thing I need to do is make the rear track bar 1/2” longer. Pumped to feel the difference. I told Tina it looks no different but it’s badasser [emoji23][emoji23]
Not sure what the recommended caster is on the PR44, but the new ball joints will take about 500 miles to break in and feel right. For you, that should be about this time next year [emoji41]Made an am trip and a pm trip. First impressions are it’s flighty. I don’t have the steering stabilizer on yet, and the Pro Steers are new. I think I’ll get an alignment and have them tell me what the caster is set at. I think I’m at 6* but I’m not positive
Lmao!! The housing said either 6* or an extra 6*, I don’t know what they mean. The driveshaft is pointed dead straight at the transfer case and the angle of the pig is 82. Factory pig angle is 88
The angle at the tcase doesn't matter. The driveshaft pointed at the front pinion should be parallel in a perfect world. But on Jeeps, it won't happen. So your aftermarket axle housing has been modified to attempt perfection. If you were to draw an imaginary line between your lower and upper ball joint, that line (near the upper section) should point rearward about 6 degrees. If it does that and you have no drive line vibrations, you are good.
Not trying to hijack the thread but where is everyone measuring the caster/pinion angle on their PR's? I know on a stock axle its recommended to measure it on the pinion flange. I'd assume thats the same on a PR but with a yoke its a bit more challenging. I feel I may have some vibes above 65mph but its hard to tell. It sounds like there may be a low toned oscillation. With win and tire noise its hard to hear. I'm not feeling anything in the seat, floorboard, or shifter. Maybe I'm just paranoid and hearing things...haha. Either way I want to know what my caster angle is first before making any adjustments.
I measure mine from the top of the knuckle and set my tool to be centered with the zert fitting on the ball joint.Lmao!! The housing said either 6* or an extra 6*, I don’t know what they mean. The driveshaft is pointed dead straight at the transfer case and the angle of the pig is 82. Factory pig angle is 88
Took Brick in to get the toe set and have them tell me what the caster is at so I can make adjustments accordingly. I had the toe in really close and the wheel centered but the caster is at 1.5
