68' M715 AKA "Smokey", 8.1 engine on links, coils and 40's
Rearmost plates which are notched to reach the rear bumper
I’ll get the inner portion near the rear channel done with MIG, at this point I need one more plate to stiffen across the pintle
Both sides are done....and a big stretch after a long hard day
Awesome job documenting this. And envious of the mill for that shave. I did a 14b with a sawzall and angle grinder. Not so much fun.
What a project. Great work. Fun to read about it and see the progress. Thanks for posting.
Just finished reading the entire thread so far. Awesome job! Someday I hope to have the time to do a big project like this. Really great job! All the nut serts and simplistic detail. Can’t wait to see the results. Love the old Kaiser Jeeps. Would love to do an old school Power Wagon or Kaiser build.
Well you Gents are too kind, thank you. I'm glad folks on enjoying this. M715's are sort of like unicorns now and if the body on this one didn't look like it had been bounced off trees, hit with rocks and backed into solid objects by some foolish Private 1st Class it likely never would have gone this route. I've got about a years worth of work now to catch up on posting and LOTS more work to go
Rear bumper inner reinforcement plate. I want to retain the factory pintle hook, hence the round hole in the center. 1/4" cold roll steel so no need to clean up nasty millscale prior to welding it
SWAG circle cutter. Simple and super handy
Clamped in place after trimming to fit
Filling in all the frame holes......because the frame is riddled with them. Along with mounting holes where the rivets went on the old brackets.
Used silicon bronze in the smaller mounting holes (since none of this is structural) and pre-fabbed tube caps on the larger ones
TrailReady's are here :clap2: Almost too nice to want to mount them
Also swapped out to a different TIG machine. Older Miller Syncrowave but it welds AWESOME compared to the multipurpose machine I was using
And this was a long time coming. Spent a full 7 hours in the shop welding out the rear axle truss and the link brackets. Slow, but likely worth it. The Syncrowave can sure lay down an awesome weld
The following contains weld porn. So shoo your kids out of the room :shock:
So at least that is done. It’ll still need a few other brackets but those can come later. Truss is a mix of 3/8” and 1/4” plate. Max amperage was 175 and the water cooled torch was such an improvement over air cooled for this much welding
Last one. Artec truss and Barnes4WD link brackets
Burned through a TON of filler rod, ER70S2
Lots and LOTS of frame plates and filling gaps/holes. Upper link bracket is welded in also
Also finished the bracing for the lower links. 2” 3/16 wall square tubing and fish plates on the frame. Should be plenty ridged and capable of handling the push/force of the lower links
Started welding the rear 4 link bungs in. Got some help to slowly spin the tube while welding so it’s one continuous weld bead. I figure that if that bung separates from the tube at some point, lots of other stuff is going to go well before it
Finished welding out all the rear 4 link bungs today. The lowers with the 3/8” wall tubing were a REAL chore.
What is the load limit on the crouch jack[emoji23][emoji23][emoji23]
Sent from my iPad using WAYALIFE
Got all 4 tires mounted and the rear links in. I was waiting on a set of left/right taps to chase the bungs after welding them
14” of clearance under the shaved 15B axle
And not ridiculously wide compared to the cab
