AllAmericanInfidel
Rig looks great brother!
Time for an update. Since post #47 I re-sprayed the cut fenders with bed liner, I broke some of the clips and bought some off of amazon. The front passenger side fender only had Amazon fender clips and flew away on the highway, thankfully it didn't hit anybody, I turned around to pick it up but it had already been mangled. I purchased Crawler Conceptz steel fenders front and rear and got them painted to match the body, I also installed the inner fenders. My next upgrade after that was the Magnaflow axle drop exhaust. Fast forward to post #48. Next up I bought the Evo 1/4 pounder. Forward to post #55 and prior to the wheeling I had ordered the winch, and as the post said I tore The rear drive shaft boot. There was a squeal after the wheeling from the rear driver side wheel and I was thinking it may have been something between the router and the dust guard so I disassembled that, turned out I had bent the flange of the axle shaft. So I ordered ten factory chromoly axle shafts for the front and rear axle, so far I have only replaced the one that was bent. I have contacted trail jeeps and got a quote for a PR44, pro steer ball joints and Revolution gears and overhaul kits, I will probably order it next month on the 4th. Right now I am back home for the holidays and went to a local spot where I could get twisted up, so I took some pictures.
How much did it cost to have your fenders color matched?
So if I'm under staying this right. You paid $1300 for both the fenders and paint?
No, that was just for materials/labor for painting. They charged me for 13 hrs labor at $90/hr + materials. The fenders themselves were $1200 for front and rear.
Fahkkkkkkk. Looks good but I would be heartbroken when they get trail pin striping at that cost. Yikes.
You got ripped the fuck off.
So $1300 for the paint job and $1200 for the fenders?
I finally received my PR44 from Trail Jeeps!! can't wait to get it installed!
My living room is starting to fell cramped!
i will probably post this question on another relevant thread, but what is everybody using for bumpstops on the PR44? i had bought some 4" synergy bumpstops to install when the axle was going to be installed but the bolt is too small for the threaded hole on the PR44.
I went to a bolt supply place and found the right size and length.
