Eddie and Cindy,
Given your experience now with several tires and having previously put Toyos and Nittos at the top, would you include these coopers in that upper category as well? I know you haven't put a ton road miles yet, but what's your thoughts on these for a daily driver? Early signs of how these tires might last term, being how I'm not familiar with the various tire compounds.
I'll be needing some new tires soon and the costs savings has me intrigued on these coopers.
Eddie and Cindy,
Glad you asked this Jags, as I am interested in the daily driver aspect of these as well. Im not due for tires yet, but my nittos look like they are starting to dry rot or something weird.
What I can tell you is this, Cindy and I really liked the 40" Nitto Trail Grapplers but after extensive use, weren't as thrilled with them in a 37" size. They just weren't the same tire, seemed to have weaker sidewalls, didn't seem to hook up as well as the 40's and neither of us liked the hard radial pull to the driver side that all Trail Grapplers have. In fact, that is part of why we started running the 40" Mud Grapplers again. Having compared the two, I would have to put the Coopers STT Pros ahead of the Trail Grapplers and so far, in the same league as the Toyo MT's. On the rocks, I'd even go so far as to say that the STT Pros hook up better than both the Trail Grappler and the Nittos. On pavement, you can hear the STT Pros a bit more than both. Again, it's too soon for me to say for sure how they will do in the long run in terms of tread life but so far, after 2,500 miles, they look to be wearing well. As far as sidewall strength goes, time will tell with this as well.
Thanks Eddie. Do you know if the SST Pro compound is different than the older SSTs? I was doing some searching and SST had some issues with chunking. But this was several years ago. You mentioned a particular compound and wasn't sure if this was new or same as years past.
It's interesting that I can get 5 new SST pros for the price of 4 nittos. My nittos still have a fair amount of tread, and a brand new spare, but I just put a ton of miles on them.
Between the tread? Mine are doing something weird as well. Like hairline veining/fracturing or something. I'm due for a rotation and actually going to show America's Tires. Not sure if just a visual thing or something else.
This is what mine look like, all 4 on the ground. My spare has a little but nothing close and it hasn't been rotated in for a long time.
Rather than when you guys bought them, look at the last 4 digits on the DOT code. That will tell you when the tire was made.
How well did they mount up to the ATX bead locks? My Nittos had a nice little recessed groove that the ring on my slabs fit nicely into.
Okay, compared to Trail Grapplers, the Cooper STT Pros were a bitch to install on our Chamber Pro II's. The bead was just so much thicker and I needed Cindy to help me get the bead seated on the mounting lip. Installing the ring took more effort too and after getting all the bolts tightened to torque spec, there was still a gap between the ring and the wheel. After putting on about a hundred miles, I went back and checked all the bolts and was able to tighten them down more. Everything is now seated more to what I would expect to see and they held up perfect in Moab.
