Nice job on the new Energy Suspension boots. I must have missed it but what problem were you trying to cure?
The loose fit of the boot and losing the grease in the rod end. It would all squeeze out the boot after about a week or so. When I'd pull the boot up there'd be hardly any in there. Figured not only would this lead to premature failure of the rod end, but also the shitty fit allowing debris and water and such in.
Ah, got it. I was over-thinking things and thought that maybe there was something else going on beyond the obvious :crazyeyes:
Really nice Jeep....good job on the build. I like anvil. I just got done trimming up the pinch seams on mine last night to "fit" the 37s..think I still need a bit more..looks like you got after them quite a bit. Off Topic - Noticed you are an IC&E... curious which plant you work at? No biggie if you would rather not say. Keep up the good work.
Thanks! I didn't actually do any trimming. The 15's come cut like that from the factory. I had a little rubbing but fixed that just by relocating the axle a little. I work for Calpine, at Los Medanos Energy Center. Are you in the industry?
Small world. I've been there since 2011. We don't use PI anymore, they switched over to eDNA. It sucks. So did you move from Houston up to CO for the new job?
Hey, so what's your thoughts/review on the Pro grips? Would assume you've driven them a little by now
Nice update. It's a sweet machine.
Nice! I keep going back on forth if the double is worth the extra money. I just threw 35"s on and I only intend to go to 37"s but its a big price jump between the double and the next step down. You happy w/ it mounted under the hood? I was debating mounting interior to help w/ heat but wasn't sure on the noise as I've never heard one run in person.
Installed my ARB twin compressor and manifold. Pretty easy except for getting everything on the manifold oriented properly so nothing would interfere with A/C lines. This thing is pretty awesome. Not as fast as my CO2 tank but it will be nice to have the extra space.
