VeruGE*144
This Sunday. Are you coming?
I really like how you relocated your differential breather hoses. Wish i could have done when I installed new tail light on. BTW, really nice fender cut! I tried door edge molding... Prfft so I need to find time to sand it smooth.
Some goodies showed up today
More goodies on the way [emoji854]
Looking good! :thumb:
7075 aluminum drag link and tie rod with 2.5 ton TRE's from Fusion 4x4. I am very pleased to see how it all arrived.
One more item on that way. Hopefully it'll be here in the next 2 weeks.
I am very impressed by the packaging and quality of the components. Can wait to get it all in.Dang that's pretty impressive packaging, I see a new steering box is on the way as well [emoji106][emoji106]
Looking forward to seeing it all installed!
Got a chance to get the EVO oil pan skid on yesterday. I figured it won't take long at all. Well I didn't notice that the lip on one side of the skid was bent s little and there was no way the oil pan bolts would pull it back to straight [emoji19]. Of course it had to be the last two bolts to go in before I noticed. I tried to push it back straight with a bar bout it wouldn't go and I didn't want to push to hard. I ended up taking it of and beating it back straight with a hammer..... about an 1.5hr and 3 beers later I was done
I Also discovered that I have a slight leak on the pinion seal, trace of gear oil coming from the yoke going down the bottom of the pumpkin. I cleaned it up with some brake parts cleaner and I'll keep an eye on it to see how bad it leaks.
As somebody posted on here before.... learn to live with a leak, embrace the leak, become the leak LOL. Damn, there is always something.
It may have taken a lot longer to do but I think you made the right decision to NOT force the last 2 bolts in. Nice job on the install :thumb:
Well that sucks. I wonder if maybe you over-tightened the bolts which can be easy to do and doing so can damage the gasket.
