Mike_JK_Houston_711
If WFO uses 1010 (worst case) there tie rod is 13.6% stronger than the $740 4130 Currie tie rod
The Currie will fail with a point load of 53,430 lbs
The WFO would fail with a point load of 61,851 lbs (assuming 1010)
The only worry is that WFO is unaware of what grade steel they are actually using. Only that it is "DOM tubing" ...
If we ASSume they are using 1020 (the most common grade Drawn Over Mandrel) it will only be in WFO's favor. Needless to say, for 65% of the cost, I went with the "minimum of 13% stronger" option. The WFO "Extreme"
sent from SPACE!
DZZ Build thread
Normally, I’d be like Eh, probably bullshit. But knowing you personally, i believe you 110% lol.
I will seriously consider the WFO at some point if/when my Dynatrac HD tierod ever fails. I’ve seen all of yours and they’re beefy AF.
