Close
Page 1 of 33 12311 ... LastLast
Results 1 to 10 of 321
  1. #1
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    41,901
    Do Yourself a Favor - Regear Your 2012-Up JK!!
    When we bought our 2012 Jeep JK Wrangler, we had always planned to upgrade it's axles to a set of Dynatrac ProRock 60's. Of course, being that money doesn't grow on trees, we decided to use the time until we could afford the upgrade to extensively test just how well a set of 37" tires would do with the new 3.6L Pentastar motor running factory 4.10 gears. For almost 2 years, we took our Jeep just about everywhere we could, driving it to and from the trail, on the highway and around town, up and over mountains, hard and fast through the Mojave Desert, up and over steep ledges in Moab and, crawling it over big rocks on trails like the Rubicon. And, after racking up over 45,000 miles on the odometer, what I can tell you is this... it can be done and it does work surprisingly, okay. For someone who's never driven a re-geared equivalent, they may not even know what they're missing.
    Having said all that, recent circumstances forced us to upgrade our front axle sooner than we had planned for and, while we were at it, decided to just bite the bullet, take advantage of Off Road Evolution's $999 special and have our Jeep re-geared with a set of 5.13's at the same time. After testing them out extensively on the 2013 JK-Experience, all I can say is - why in the hell didn't we do this sooner!!
    While the 3.6L motor has a good amount of power and will do a decent job of compensating for larger tires, it simply can't make up enough of a difference especially in situations like on long or steep hill climbs. Here, your transmission will try to help make up the difference by dropping gears and running your RPM's up close to 6 grand just to keep you moving. Of course, this will cause your engine and transmission to run really hot and in some cases, cause your Jeep to go into limp mode - ask me how I know. With a set of 5.13's, this will no longer be an issue as you'll have plenty of power to do the same job in a higher gear and running at a lower RPM. Of course, this is to say nothing about the fact that on the rocks, a set of 5.13's will also significantly improve your crawl ratio - running 37" tires on 4:10 gears, you'll go from a 3.36:1 to a full 4.21:1! Of course, for those would might complain about the increase in RPM at highway speeds, what I can tell you is that it's really insignificant. In fact, the difference you'll see when compared to a stock Rubicon running 32" tires and 4.10 gears is only about 200 RPM as you can see in the calculators below:
    2012 Jeep JK Wrangler Rubicon - 32" Tires w/4.10 Gears
    2012 Jeep JK Wrangler Rubicon - 37" Tires w/5.13 Gears
    Trust me, if you're planning on running 35", 37" or bigger tires on your 2012-Up JK, you really will be doing yourself a BIG favor to get it re-geared at the same time. If you live in the SoCal area, be sure to take advantage of Off Road Evolutions $999 special too as it really is a deal that is hard to beat
  2. #2
    Been Around the Block Sithwindu's Avatar
    Join Date
    Jan 2013
    Location
    Corpus Christi
    Posts
    466
    So the pr 44 and bolt ins killed it on jkx?! Making me want to regear now heh ill have to give 5.13's a try
  3. #3
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    41,901
    Quote Originally Posted by Sithwindu View Post
    Yep, running 37" Nitto Trail Grapplers with 5.13 gears was a winning combination! It's definitely what I would recommend even on a 2012-up JK.
  4. #4
    Fresh Catch
    Join Date
    Feb 2012
    Location
    Australia
    Posts
    11
    Few things
    Changing your Ring and pinion is helpful but the higher you go the weaker it becomes. You are able to run 37s on a Dana 30 as long as you don't go higher than 4:56 gear ratio.
    also are you going to keep running 37s for a couple of years because you now have a pro rock 44 and your getting a rear 60 from Moby. Seems kinda pointless to have 2 jeeps that are both on 40s and exactly the same.
  5. #5
    Join Date
    Jan 2013
    Location
    Corpus Christi
    Posts
    466
    I'm runnin 35 mud grapplers on my 2013 jku, went to a mudfest this past sat and felt I could really use a bit more power 3.73 isn't giving me the power this engine wants to output!!
  6. #6
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    41,901
    Quote Originally Posted by UnIuckychucky View Post
    Believe me, you're talking to a guy who knows this first hand. In a Dana 44, I would not recommend running anything higher than a 5.13 even if a higher ratio like a 5.38 will provide better performance results. In a Dana 30, I typically don't recommend anything higher than a 4.88.
    Well, that's kind of become the plan now even though I would prefer to have 2 Jeeps running 40's
  7. #7
    Hooked kRay.JK's Avatar
    Join Date
    Apr 2013
    Location
    Knoxville, TN
    Posts
    147
    But what about a 3.8L motor - lost cause to have the best of both worlds?
  8. #8
    Nothing but a Thing NFRs2000NYC's Avatar
    Join Date
    Mar 2013
    Location
    NYC/NJ
    Posts
    2,476
    You don't think 5.13s are a bit too high for a 2014 with 35 (34" effective?) I'll be getting mine with 4.10s, and figured if it's not enough, I'll bump it to 4.56, but Im afraid 5.13 would be a bit too high...unless I misunderstood your post and you weren't specifically telling people to get 5.13s but just to regear?
  9. #9
    Nothing but a Thing pvanweelden's Avatar
    Join Date
    Apr 2013
    Location
    Des Moines
    Posts
    2,034
    Quote Originally Posted by kRay.JK View Post
    Regearing will also help the 3.8 (will help any motor)
    Anytime you increase wheel size, regearing at the appropriate ratio, will maintain stock performance.
    But it is not cheap, so plan accordingly, and if you plan on sticking with a certain tire size, definately regear.
  10. #10
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    41,901
    Depends on what size tire you are wanting to run. With an old 3.8L and 37" tires, the ratio you would want to run is 5.38 but, that will leave your pinion really small and a weak point. Because of this, I wouldn't recommend that you run anything more than a 5.13 on that setup. Trust me, I've run both on my 2007 and speak from experience here.
    Quote Originally Posted by NFRs2000NYC View Post
    My only point was to recommend that you regear. As I had stated multiple times, 5.13's is what I would recommend with 37's but would probably go with 4.88 if I were running 35's.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
