desertrunner
Thanks man yeah I would love to see a pic of your set up and your measurements. I went the OME 2.25 med duty no load springs.The rig is looking great man!
Which OME springs are you using in the rear? I have the 2.25" OME in the rear and the Synergy raised trackbar mount and it seems pretty centered. The only issue I had with it was shock clearance. I can get some measurements for you later if it'd help at all.
Side note I just mounted my spare and took measurements and I am 7/8" off to the passenger side. Just enough to make me want to do something about it. That's with a full tank of gas too. Obviously it will always change with weight but that's almost as loaded as its gonna be and it's still 1" off that's too much for my taste.
The JKS bracket says it raises the track bar mount 4" I wonder how much that equates to lateral axle movement
